Configuration reply to the application was dropped, as %client% application is not running at the time. %seqNum% is a sequence number that is assigned to every request that the configuration manager receives. %msgType% is the message to the request with sequence number - %seqNum% that was associated with the %client% application.
The application is most likely not running at the time (either crashed or not started). Either restart the application or reboot the switch.
Error
Response(%msgType%) to request number(#%seqNum%) handled by client (%client%) dropped, as %client% not running
| Name | Type |
| seqNum | uInt32 |
| client | String |
| msgType | String |
